Page 2 of 2
Re: newbie alert in kent
Posted: Sat Feb 08, 2020 3:46 pm
by garry inglis
welcome to forum
Posted: Mon Feb 10, 2020 2:19 am
by paul d
Hats off for taking on such a big project. That will definately be one saved from the grave! Looking forward to seeing it come together. Best of luck with it.
Posted: Sat Apr 18, 2020 8:36 pm
by redratbike
I posted up a while ago regarding a rusty series 1 lambretta , I bought it with the frame loop chopped off and that was beyond repair so got another that had had the side panels welded on , so chopped those off , still rough but better .. had the frame blasted and it was a little dimpled in one place with rust so my mate attacked it today at his work .. we respected the 2 metre rule
I bolted on the frame loop as the frame still had the spot welded plates from where it was removed from the old loop so this lined everything up and he welded the acquired loop on
The main frame had a heavy dimpled section so I made a plate up this was drilled for plug welds and was tacked ,plugged and seam welded
There were a few fatigue cracks around some holes that I got him to fill up on the rear of the loop
The front frame had a hole so I made a plate up a couple of weeks ago I had drilled it so it could be plug welded then sealed
After all this was done I gave it a quick blast of grey I had laying around to protect if for now
Just need to get all the bodywork together now so I can start thinking about a ratty paint job and actually putting the thing together.
A good day in lockdown 👍👍👍
Trying to upload pics
Posted: Sat Apr 18, 2020 8:44 pm
by hendy
Well done. Photos please?
Posted: Mon Apr 20, 2020 4:10 pm
by redratbike
hendy wrote: ↑Sat Apr 18, 2020 8:44 pm Well done. Photos please?
here you go , I hope!
pics showing , the other frame loop I bought this had welded on side panels which needed cutting off, they are rough but it isn't going to be a show scooter , ratty and rideable .
https://ibb.co/WsDTKcq
https://ibb.co/fxX6t2v
https://ibb.co/CWVT7PL
https://ibb.co/890mBzM
https://ibb.co/FbhyzYt
https://ibb.co/hRwSYsR
https://ibb.co/7tGvHzZ
https://ibb.co/P4cczk7
https://ibb.co/xGDvZpK
https://ibb.co/cQY33Cm
https://ibb.co/jycg1nb
https://ibb.co/gjrNRR8
https://ibb.co/bgVjJdf
https://ibb.co/7SqtTKB
https://ibb.co/7kjY1JP
https://ibb.co/hyR1RMb
https://ibb.co/QjFXRnF
Posted: Mon Apr 20, 2020 4:12 pm
by redratbike
Posted: Tue Apr 21, 2020 5:59 am
by Toddy
Nice work , good luck with your project :D
