Page 2 of 2
Re: 210 polini alloy cold start issue
Posted: Fri Jun 21, 2019 2:27 am
by Davidsquaredson
Sorted. The choke jet (60) is too lean. If I wound out the mix screw past 4 times it would almost catch. So I went with a 50-120 idle jet. Fat but doesn't impact the main jet much. I have mix screw turned out 3 times. Starts first kick on cold. It's raining too hard to check the rest of the throttle range but I'm on the path to glory.
Sent from my Pixel 2 using Tapatalk
