Page 2 of 5
Re: Cracked casing
Posted: Sat Oct 20, 2018 8:00 am
by garry inglis
In workshop at 6am must be mad on with engine mounts so I can get it on my standImageImage
Re: Cracked casing
Posted: Sat Oct 20, 2018 8:01 am
by garry inglis
Then the layshaft and gear selector Image
Re: Cracked casing
Posted: Sat Oct 20, 2018 8:02 am
by garry inglis
Then my li150 gearbox and endplate shimmed upImage
Re: Cracked casing
Posted: Sat Oct 20, 2018 8:04 am
by garry inglis
Love these new 4mm stainless sealplate studs and lock nut from Mike at torbay lambretta less than £3Image
Re: Cracked casing
Posted: Sat Oct 20, 2018 9:20 am
by holty
nice work garry, exhaust port is a nice shape, i little bit of grinding to be done, keep at it matey.
Re: Cracked casing
Posted: Sat Oct 20, 2018 9:42 am
by garry inglis
I thought you might notice that
Re: Cracked casing
Posted: Sat Oct 20, 2018 1:38 pm
by johnny650
cracking start today garry. Did you get the case welded in the end or are you using a spare ?
Do you use any threebond on the drive side halite washer ? I have nightmares about leaking drive side seals
Re: Cracked casing
Posted: Sat Oct 20, 2018 2:19 pm
by garry inglis
Hi I bought another casing a new Indian 200 as I couldn't get a response on welding and I have 3 offers now so I will get that fixed and I don't put threebond on the drive seal just a smear of grease and tighten it up I've got all that done today will put dome more pics up
Re: Cracked casing
Posted: Sat Oct 20, 2018 2:21 pm
by garry inglis
Casing matched to barrel Image
Re: Cracked casing
Posted: Sat Oct 20, 2018 2:22 pm
by garry inglis
Driveside bearing in and mb plateImage
