Page 2 of 4
Re: Scooter not picking up properly ........... HELP!
Posted: Sun Sep 30, 2018 8:23 pm
by alanscottj
Scooterdude wrote: ↑Sun Sep 30, 2018 8:10 pm When you charge your stator dont ditch the old one. Instead buy and fit a Ducati/Piaggio lt coil and pick up and keep as a spare.
Thanks for the tip, I'll be sure to do that. I really hope it sorts the problem as it's driving me around the bend!
Now, I am not sure which flywheel I have (light/mid etc) - can I just buy any stator and swap it? If so which is the best?
Posted: Sun Sep 30, 2018 8:37 pm
by garry inglis
A.c. or dc have you a battery bgm or scootronics around £85
Posted: Sun Sep 30, 2018 8:39 pm
by garry inglis
This is scootronics a.c. and I just fit external pickup Image
Posted: Sun Sep 30, 2018 8:47 pm
by alanscottj
garry inglis wrote: ↑Sun Sep 30, 2018 8:37 pm A.c. or dc have you a battery bgm or scootronics around £85
No battery - AC - think I'll message Anthony and see if he has any ready to go, failing that i'll go BGM :D cheers bud
Posted: Sun Sep 30, 2018 8:49 pm
by garry inglis
He's in Korea next week so a week on Monday before you can order bgm are good
Posted: Sun Sep 30, 2018 9:04 pm
by alanscottj
garry inglis wrote: ↑Sun Sep 30, 2018 8:49 pm He's in Korea next week so a week on Monday before you can order bgm are good
Yes, he just messaged me! Cheers bud :D
Posted: Sun Sep 30, 2018 9:11 pm
by Scooterdude
Yes the Anthony Tambs ones are very good, the BGM ones not so good. Mine went within 6 months from new and ive heard similar stories.
If you can get a SIL one from Scooter Restorations in Nottingham that may be a better choice.
Posted: Mon Oct 01, 2018 8:00 am
by Daggs
If I've followed this ? You've effectively tried two CDi's and two pick-ups.
In my experience LT coils break down when hot. This means when the scoot has been running for some time and/or distance.
I'm not certain it's an electrical problem.
I'm wondering about the carb. and or settings. Or perhaps a mechanical problem.
Without seeing the scoot for myself it's difficult to diagnose.....
Posted: Mon Oct 01, 2018 8:58 am
by HxPaul
I have an AC system and I use one of these - https://www.facebook.com/photo.php?fbid ... ater&ifg=1 - It takes its power from the lighting coils,so with your external pick up and this CDI it cuts out everything apart from the lighting coils from your stator plate.
Posted: Mon Oct 01, 2018 1:23 pm
by johnny650
I'm inclined to agree with Daggs that it is a carb issue .
Clearly it is only effecting the throttle pick up off of idle by your description .
The idle is presumably stable so rather than the Pilot jet or air jet it could be the slide...... the slide is responsible for pick up off idle to approx 1/8th of throttle range.
Try this simple experiment. next time you go to pull away apply a little choke and see if that improves initial pick up. if it does pick up better then it would suggest you need to change your slide to a richer one .
from MB Scooter site 'Dellorto slides 26 - 30mm PHBH 30 35 40 45 50 55 Alloy
