Page 2 of 2
Re: GP tail light bulb blowing
Posted: Thu Sep 27, 2018 6:09 pm
by warts
I should add, you let the silicone go off first, before fitting...
Posted: Fri Sep 28, 2018 12:59 pm
by holty
its probably the voltage regulator thats faulty, replace with a ducati one.
Posted: Fri Sep 28, 2018 2:50 pm
by Mrnice71
holty wrote: ↑Fri Sep 28, 2018 12:59 pm its probably the voltage regulator thats faulty, replace with a ducati one.
Yes but other bulbs not blowing
Posted: Sat Sep 29, 2018 8:15 am
by holty
Mrnice71 wrote: ↑Fri Sep 28, 2018 2:50 pm
sorry i should have read the post more carefully, i would guess at a bad earth on the back light could be to blame, i always run one from maghousing to frame then regulator, then onto back light, might be worth a try
Posted: Mon Oct 01, 2018 5:21 pm
by Daggs
When I've had an over voltage from the Reg. It always seems to get the rear light first. Gawd knows why!
If you have a multimeter? Check the output. Expect anything between 11v and 13v, they aren't that accurate.
Posted: Mon Oct 01, 2018 10:49 pm
by Mrnice71
Daggs wrote: ↑Mon Oct 01, 2018 5:21 pm When I've had an over voltage from the Reg. It always seems to get the rear light first. Gawd knows why!
Not got a multimeter daggs , lm just gonna put an LED in when it goes again pal lol
Posted: Tue Oct 02, 2018 7:51 am
by holty
too much voltage will still blow an led, i still suspect that it will be down to the voltage regulator or the earth, i would replace both and see if that fixes it.
