Re: pacemaker box
Posted: Wed Jan 14, 2009 10:49 pm
why ? did he break one ?RinB wrote:Q Dave![]()
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
thanks for thatdavidblythe wrote:am using a late loose 3rd pacemaker gear (same as spanish li 150 3rd gear btw) on an early xmas tree on a TS1
had to modify the xmas tree to allow the teeth to mesh but it has been fine for the last 1000 miles
SX200 ~ 37 teeth ?Ketje wrote:I've put a 3rd loose gear from SX200 in my early pacemaker gearbox.
Yes indeed, it works for Vespa's to switch gear-cogs with or two teeth more or less, so why wouldn't it with Lammy's. It worked for me so far.byron wrote:SX200 ~ 37 teeth ?Ketje wrote:I've put a 3rd loose gear from SX200 in my early pacemaker gearbox.
I like your thinking.Ketje wrote:Yes indeed, it works for Vespa's to switch gear-cogs with or two teeth more or less, so why wouldn't it with Lammy's. It worked for me so far.
Mike.
You should check the diametre in Sticky's book.byron wrote: I like your thinking.
I shall see what I can get hold of.
would the Li150 37 tooth 3rd gear also work I wonder...?
