pacemaker box
RinB wrote:Q Dave ;)
:lol: :lol: :lol:
why ? did he break one ?
RinB
No but sounds like break ;)
davidblythe
am using a late loose 3rd pacemaker gear (same as spanish li 150 3rd gear btw) on an early xmas tree on a TS1
had to modify the xmas tree to allow the teeth to mesh but it has been fine for the last 1000 miles
davidblythe wrote:am using a late loose 3rd pacemaker gear (same as spanish li 150 3rd gear btw) on an early xmas tree on a TS1
thanks for that
will see what's about and what needs doing
Ketje
I've put a 3rd loose gear from SX200 in my early pacemaker gearbox. The top-end is a TS1 225. still standing after enough miles to break. Always keep in mind that 3rd "could" snap and caution will come as a natural reflex :-)
Mike.
Ketje wrote:I've put a 3rd loose gear from SX200 in my early pacemaker gearbox.
SX200 ~ 37 teeth ?
Ketje
SX200 ~ 37 teeth ?
Yes indeed, it works for Vespa's to switch gear-cogs with or two teeth more or less, so why wouldn't it with Lammy's. It worked for me so far.
Mike.
Ketje wrote:Yes indeed, it works for Vespa's to switch gear-cogs with or two teeth more or less, so why wouldn't it with Lammy's. It worked for me so far.
Mike.
I like your thinking.
I shall see what I can get hold of.
would the Li150 37 tooth 3rd gear also work I wonder...?
Ketje
byron wrote: I like your thinking.
You should check the diametre in Sticky's book.
Greetz, Mike.
twin
just buy a new one from DavesGearBoxes,
£375 a set,
    Users browsing this forum: No registered users and 72 guests
