Page 2 of 3
Re: Stopping panels falling off
Posted: Tue Jul 17, 2018 6:42 pm
by Warrick
Doom Patrol wrote: ↑Mon Jul 16, 2018 11:43 pm Are the panels straight and fit nicely all along the loop?
Nope they are not great, they are a pig to fit
Posted: Tue Jul 17, 2018 6:46 pm
by Warrick
Toddy wrote: ↑Tue Jul 17, 2018 6:10 am What sort of Clips are you using some Cheap reproductios loose their tension very quickly
Think I got the from the scooter surgery at the big 7 about 5 years ago after my panel fell off on the ride out, it’s not a new think but it’s now been sprayed:-(
Posted: Tue Jul 17, 2018 8:45 pm
by Doom Patrol
Warrick wrote: ↑Tue Jul 17, 2018 6:42 pm
That could be half your problem. If the panels aren't flat they'll be sprung when you force them into place.
Posted: Tue Jul 17, 2018 9:23 pm
by Warrick
Doom Patrol wrote: ↑Tue Jul 17, 2018 8:45 pm
How would the best way to get them flattened? The problem panel is the right hand side
Posted: Wed Jul 18, 2018 7:16 am
by Minority
What's the state of the panel buffer on the outrigger? If it's badly worn this can cause the panel to be loose.
Posted: Wed Jul 18, 2018 12:13 pm
by Doom Patrol
Warrick wrote: ↑Tue Jul 17, 2018 9:23 pm
Ideally, I suppose, it should be sorted by a good panel beater at the prep stage. It's a tricky one. If it's flown off for other reasons it might have become twisted anyway. But basically a straight panel is what you want.
Posted: Wed Jul 18, 2018 6:57 pm
by Warrick
Minority wrote: ↑Wed Jul 18, 2018 7:16 am What's the state of the panel buffer on the outrigger? If it's badly worn this can cause the panel to be loose.
Not great, it’s always been the right hand side. I think the panel is twisted the clips are weak and the buffer is shot. I likes to make it 100% when I’ve got the panel redone.
It was alway very tight with the buffer it caused the paint to crack
Posted: Wed Aug 08, 2018 12:01 pm
by Leo
Jumping off panels can also be attributed to the frame loop. Some of the scooter importers have a nasty habit of transporting the Lambrettas standing up on their rear number plates to get more of them in their van.
This can shorten the frame loop a bit and makes the panels fly off for fun. A scissor jack between the engine block and the reg plate area of the frame can get your frame loop back to the correct length.
There is a drawing somewhere online that shows the correct length.
A sign the frame is too short can be on a machine with panel handles is that the handles do not sit parallel to the ground.
Posted: Wed Aug 08, 2018 2:53 pm
by Adam_Winstone
Posted: Wed Aug 08, 2018 6:38 pm
by wrecklessrobbie
Funnily enough...i was looking at and reading that last night Adam. I fitted my panels onto my S2 last night.
First time they have been on the scooter in about 3 if not 4 years.
One of them the front end looked like it wanted to pop out and did once.
The handles are very tight at the back and working very well.
I have fitted new panel rubbers to the frame.
I noticed MB advise fitting them into the panels in line with the rear frame badge.
Has any one put them further along the panels ?
Or even near the bottom of the panel near the Bridge piece.
The panels appear straigh. I have new leg rubber buffers fitted.
I have left them on to see if they bed in.
Am not sure fitting locks by the rear frame badge would hold them.
Hopefully that all makes sense.
