Page 2 of 2
Re: Help!! Keep breaking reed petals in a TS1
Posted: Fri Jun 29, 2018 12:11 pm
by Mrnice71
Mark 1 wrote: ↑Thu Jun 28, 2018 7:39 pm Thanks for the idea Mrnice,
I think the clearance issue will be with the back bolt with the shallow head rather than the manifold itself so a longer shock may help. But, how far to go, new shock, reed block, packer, even try the LTH manifold. All hard earned pennies when there is possibly some underlying problem. Someone on the other forum broke two sets and turned out to be a dodgy plug, so could be simple :? I hope!!
Interesting you had a 3mm packer with a standard reed block and altered the stops. Was that recommended by someone? Especially as you had no issues. I look at the stops on the bgm block and think “they must be there for a reason”.
Mark
The reed stops are altered one side so they dont obstruct the boost port as much
Posted: Fri Jun 29, 2018 2:50 pm
by Muppet
use a shorter rear shock for more clearance at the reedblock manifold not a longer one
Posted: Fri Jun 29, 2018 5:05 pm
by Mark 1
Thanks Mrnice may google the altered stops just to see what gets done.
Doh! Correct muppet. Could try and nick the adjustable BGM shock off the wife’s scooter. She’ll probably never notice :D
Mark
