Re: 1/4 turn fasteners
Posted: Mon Jun 04, 2018 11:49 pm
Good work.
I've ordered a sizing kit to see what's possible.
The problem with the Lince is that the horncast is only attached by the two screws at the front and the nuts and bolts underneath which attach it to the mudguard - these are impossible to undo without removing the whole front end so you can't take the horncast off by itself to do wiring, cables etc.
I tried chimney nuts on the horn cast - mudguard connection but these are almost as hard to undo from underneath and aren't conducive to a good fit between the horncast and the legshield.
