PHBH carb leak
HxPaul
When you put the float bowl on,its the jet that goes inside the float bowl.
flipster
Mrnice71 wrote: ↑Sat Mar 24, 2018 1:24 am Float height not right , constantly filling bowl , float needs adjusting so it shuts the float needle valve jet off sooner
I agree with Mrnice , worth checking . Av a look at this - ( Fuel supply system - 3.2.2 ) .
http://members.iinet.net.au/~petercusac ... o_3_2.html
Also check/clean or replace the float needle , should have a red tip ! :)
To check if the float needle is working correctly , blow down yer banjo :oops: and gently lift the float which should stop the air .
Good luck !
Cheers.
P.N.D.S.C.
