MBD 170 T5 kit.
gaz_powell
An oversized Suzuki TS185ER piston goes in a malossi 172, you need to cut the skirt and add an inlet window, then finally reprofile the head to match the dome of the Suz'i piston.
I just did it for the sake of it on a barrel I acquired.
soulboy
Tsr revolver is the best pipe ever used on a t5 ...I had both the mb Suzuki and the yam one the latter was nuts but need cases mouth opened up with nfk 350 reedblock and a 32 mm amal wernt a lot to beat that lol
