Page 2 of 2
Re: Rear sprocket stiff.
Posted: Fri Nov 17, 2017 3:13 pm
by ove
Just to finish this off in case anybody ever has the same issue, changed the 0.75mm clutch shim to a 1.2mm shim and it clears the problem.
Thanks for all the suggestions.
ove.
Posted: Sun Nov 19, 2017 4:24 am
by Minority
Hi Ove, just had exactly the same problem
, just another possible solution to using a thicker shim, with mine it was just the ears of the circlip causing the problem so I just put a bit of a chamfer on the ears with a dremmel. No effect on the integrity of the circlip and gave enough clearance for the crownwheel. I'm guessing it was an aftermarket crownwheel, mine was
. Your post saved me from a lot of head scratching so thanks for that!
Posted: Tue Nov 21, 2017 6:44 am
by ove
No worries minority, mine was AF road cassette with a GT endplate. It was possibly the circlip ends sticking up slightly as you said.
