Page 2 of 2
Re: Tools to cary
Posted: Sun Oct 29, 2017 7:23 pm
by wrecklessrobbie
Hi Mick
Did you go to Brid?
Whos was the eibar with legshield toolbox with york saxon scooter club badge on it. Looks a nice scooter. Whats he running in it?
Re: Tools to cary
Posted: Sun Oct 29, 2017 7:30 pm
by wrecklessrobbie
I read on here sometime ago that you should try and change as many things as you can to allen key bolts etc. So you can carry a set of allen keys. Lighter and take up less space in the toolbox.
Mindst not a good idea to do the crankcase side in allen bolts it can strip the threads.
I have spare wheel ...inflated!!
Spare clutch, gear and front brake inner.
Rac card 😊
Re: Tools to cary
Posted: Sun Oct 29, 2017 8:13 pm
by mick1
wrecklessrobbie wrote: ↑Sun Oct 29, 2017 7:23 pm Hi Mick
Did you go to Brid?
He's running an Avanti kit with a TSR/Taylor exhaust, he;s done quite a few miles on it now, including the German Euro last year and a trip round the Low Countries (including Luxembourg) this year.
Re: Tools to cary
Posted: Mon Oct 30, 2017 2:49 pm
by EddieStone
For longer trips it's more important to carry the spare parts and the special tools than normal tools. You can normally find someone happy to lend you tools, but something like a CDI or a flywheel puller is hard to come by.
[I've used a piece of rope with a knot in it as a flywheel locking tool in the past. Shove it down the plug hole and turn the engine til it locks. Desperate times call for desperate measures!]
Re: Tools to cary
Posted: Mon Oct 30, 2017 10:44 pm
by psychedelicropcircle
GeorgeS wrote: ↑Sat Oct 28, 2017 7:02 pm Cable ties and gaffer tape are often useful to get your new girlfriend home.
Sent from my SM-G920F using Tapatalk
Re: Tools to cary
Posted: Mon Oct 30, 2017 10:58 pm
by Meds
Think about it this way
2 miles from home is a bloody long push
If you can fix it in 10-20 mins using tools and spares available it's better than waiting for the AA or someone to bring the kit.
If you built it you know the spanners, Allen keys and screwdrivers you need .
M7 nuts and a spare set of lamps are worth carrying as most places don't stock them.
Cables and the kit needed to change them ( I carry a throttle, gear and a couple of clutch cables)
Re: Tools to cary
Posted: Tue Oct 31, 2017 12:01 pm
by Bilko
For my trip to France I took:
Spanners
7, 8, 9, 10, 11, 12, 13, 14, 17, 19,
Sockets 1/4 6, 7, 8, 9, 10, 11, 12, 13, 14, 17, 19,
Spark PLug Socket
1/4 and 3/8 Extension Bars
1/4 to 3/8 Adapter
3/8 to 1/4 Adapter
Adjstable Spanners
Screw Driver flat, flat short, Phillips, and small double
Pliers
Snips
Allen Keys
Mole Grips
Torque wrench
Knife
Circlip pliers
2 gear cables
2 clutch cables
2 throttle cables
Cable trunnions & clutch cable trunnions
solderless nipples
Seals
Circlips
fuel pipe & Fuel pipe clips
Carb hose
Carb hose jubilee clips
HT lead
HT cap
CDI
Woodruff Keys
Carb Jets, needles, Atomisers, Carb Needle Clips
Stator plate
Spark Plugs
Headlight Bulb
Piston
Piston Rings
Piston Circlips
M7 Nuts & Washers
M8 Nuts & Washers
M7 Kickstart Bolt
Nuts & Bolts
Clutch Compressor
Clutch Holder
Flywheel Holder
Flywheel Extractor
Piston Stop Tool
Gearbox oil
Loctite
Gasket Sealant
Insulation Tape
Torch & Head Torch
As well as a layshaft, a hub, and a fuel can.
The best bit about it is, I broke down on the way back in England when my reed block cage came apart. One spare I didn't have, but I managed to get one at the Shipston on Stour 4 Nations Rally to carry on my journey back to Belfast.
Re: Tools to cary
Posted: Tue Oct 31, 2017 3:13 pm
by paul d
Love the knotted rope bodge mentioned earlier, it works! I carry spares similar to BIlko. I use old tobacco tins for things like woodruff keys and screws/bolts. Plastic lunchboxes are handy for things like stator plates. I've got one that takes the regulator and cowling screws too. I wrap tools and sockets with tea towels to stop those worrying rattles than ruin long trips.
Re: Tools to cary
Posted: Tue Oct 31, 2017 5:25 pm
by EddieStone
I have a CDI unit cable tied to one of the rear footboard brackets. I keep my cable inners under the seat, between the springs and the foam. I don't have a legshield toolbox, so space is limited. Most of my tools are in a black pencil case from Wilkinsons that cost £1.50. It holds a surprising amount and squishes down better than rigid boxes. Doesn't rattle either.
