Page 2 of 2
Re: and then me balls fell out
Posted: Sun Sep 24, 2017 11:28 am
by Minority
I made up this little tool to help, still not easy to do with layshaft fitted in casing, but it makes it a bit easier :D
Image20170923_175516 by John Stacey, on Flickr
Posted: Sun Sep 24, 2017 2:05 pm
by garry inglis
That's looks just the same as my two screwdrivers lol nice one minority
Posted: Sun Sep 24, 2017 2:54 pm
by johnny650
Minority wrote: ↑Sun Sep 24, 2017 11:28 am I made up this little tool to help, still not easy to do with layshaft fitted in casing, but it makes it a bit easier :D
nice tool Minority.......... I like home made tools but it wouldn't fit in the case with the layshaft fitted unfortunately. :cry:
Posted: Mon Sep 25, 2017 4:40 am
by Minority
It does, just (like most things in the lambretta gearbox/clutch/kickstart area, they just fit). I used it to change the detent spring between the two ball bearings. I foolishly changed to an MB up-rated spring at one stage which made the changing gears painful (literally), so I wanted to change the spring back to standard. I made this tool to achieve this without stripping the back hub and layshaft out of the casing after spending hours and much swearing trying to do it with just my hands (no headbutting involved :) )
Posted: Mon Sep 25, 2017 9:25 pm
by rosscla
This nearly drove me nuts on my last motor. I had a tight spot on the box in third and fourth which wasn't that apparent till the box was assembled. I had it in and out a dozen times before I eliminated it by bending the yoke, but I must have pushed it past 4th and popped the balls out every other time...
Posted: Mon Sep 25, 2017 11:38 pm
by corrado
Trevor Emerton used to sell a very simple tool for that job. Not sure if he's on here.
https://www.facebook.com/beverleylambre ... lds.bler.1
