Page 2 of 2
Re: Size
Posted: Sun Sep 10, 2017 1:14 pm
by cgt75b
a.lo.v2 wrote: ↑Sun Sep 10, 2017 12:00 pm just a point to consider, most of the supplied kits have flat or crosshead screws which you will never get a screwdriver on with the engine and tank fitted. I always buy separately m4 hex screws that enable my 1/4 inch socket to get on in situ. handy if you are having stator problems at side of road.
This is exactly the reason why I am asking the question.
Thanks for your input.
Re: Size
Posted: Sun Sep 10, 2017 3:30 pm
by HxPaul
Just use m4 studs with m4 nylock nuts.
Re: Size
Posted: Sun Sep 10, 2017 4:23 pm
by cgt75b
HxPaul wrote: ↑Sun Sep 10, 2017 3:30 pm Just use m4 studs with m4 nylock nuts.
[/quote
Cheers for the tip, very much appreciated.
Re: Size
Posted: Sun Sep 10, 2017 9:47 pm
by rosscla
Ah for the the wiring plates. Yes M4 grub screws and nylocks, just done that on my latest engine. You need them about 25 mm, they don't bottom out so use loctite
Re: Size
Posted: Wed Sep 13, 2017 3:26 pm
by cgt75b
Thanks :D
