Page 2 of 2
Re: Gp flooding or fuel starving
Posted: Fri Jul 07, 2017 7:43 am
by HxPaul
Scooterdude wrote:Ive recently suffered the same scinario going round right hand corners, turned out to be the float set at the wrong height. it was flooding btw....
Theres only one setting for the jetex carb.........
Posted: Fri Jul 07, 2017 8:35 am
by Scooterdude
HxPaul wrote:Scooterdude wrote:Ive recently suffered the same scinario going round right hand corners, turned out to be the float set at the wrong height. it was flooding btw....
Float valve, leaking or damaged float then.
Re: RE: Re: Gp flooding or fuel starving
Posted: Fri Jul 07, 2017 9:21 am
by dazblakey
garry inglis wrote:Do you get me
Yes mate, but I'm running a different filter one that fits the mouth of the carb
Sent from my D6603 using Tapatalk
Posted: Fri Jul 07, 2017 9:24 am
by garry inglis
It won't be that then
don't think the jettex is a bad carb I've used a couple of 22mm and once jetted correctly they are great
Posted: Fri Jul 07, 2017 1:38 pm
by dazblakey
garry inglis wrote:It won't be that then
Been over several times everything checks out
Posted: Fri Jul 07, 2017 6:59 pm
by mick1
Could be electrical ? Have you tested the stator ?
Posted: Fri Jul 07, 2017 8:35 pm
by dave81
I had this problem once when out on a Sunday afternoon ride. On a right hand turn it cut out. Found the choke plunger spring had broken so it allowed fuel to come out of the choke jet. This filled up the breather pipe so when I turned right the fuel ran down into the Jetex and flooded it.
Posted: Sat Jul 08, 2017 5:31 am
by dazblakey
I've checked the stator right ohms etc and checked the choke see no joy
Posted: Sat Jul 08, 2017 8:09 am
by HxPaul
joespeed wrote:and run with the filler cap slack or removed
This is good advice
http://www.ilambretta.co.uk/forum/viewt ... cap#p72802
Posted: Sat Jul 08, 2017 1:22 pm
by dazblakey
Tried it
