Re: RE: Re: RE: Re: Recommend 175 kit
Posted: Wed Jun 28, 2017 6:15 am
Cheers ryanRyskie wrote:PJ Engineering in Wednesfield could sort the re-bore and probably sort a piston as well for you mate.dazblakey wrote:Cheers Chris sounds like a planbristolmod wrote:
+1. should come in well under £300.
Off the top of my head and using Scooter Restorations- Piston say £40; Head say £30; Rebore say £40; gaskets £5. Up the main jet a tad (assume you're using the standard 22mm carb?)
bore cylinder to 3.5 thou in old money.
Nice load of hot/cold cycles for running in and away you go.
Chris
Sent from my D6603 using Tapatalk
