Recommend 175 kit
dazblakey
Ryskie wrote:
dazblakey wrote:
bristolmod wrote:
+1. should come in well under £300.
Off the top of my head and using Scooter Restorations- Piston say £40; Head say £30; Rebore say £40; gaskets £5. Up the main jet a tad (assume you're using the standard 22mm carb?)
bore cylinder to 3.5 thou in old money.
Nice load of hot/cold cycles for running in and away you go.
Chris
Cheers Chris sounds like a plan
Sent from my D6603 using Tapatalk
PJ Engineering in Wednesfield could sort the re-bore and probably sort a piston as well for you mate.
Cheers ryan
YAMLAM
Or Harry Barlow at pro porting,he can sort the lot out for you,his 175 tunes are very good and very reasonably priced. Give him a call 0116 287 1285.
win or lose have a booze
    Users browsing this forum: Amazon [Bot] and 2 guests
