GPS tracker...
eden
fluff34567 wrote:you are using the same dog tracker above and have it hidden in the framework or under the headset etc? Can go to PM if you prefer.
No it's a different tracker.
Yes it's well hidden in the scooter.
Those dog trackers are shite!
fluff34567
I was referring all time to the dog tracker... if yours is working well under metal then great. I have a SPOT and it doesn't transmit under the bodywork.
eden
Mines well tested under normal conditions.
The idea of the site I linked to is to test the tracker on a long trip which takes in some extremely remote areas.
It may or may not work... I'll find out soon :)
fluff34567
Sounds good.. I have a link for mine somewhere have to find a link.
fluff34567
Found it... I set it to update every few hours when on so it's widely spaced but it does ping the satellite every ten mins.
https://spotwalla.com/publicTrips.php?un=Rob4
fluff34567
To answer a message i recieved.. go north from point 97 that's where I started(zoom in see the balcony) down to Venice then ferry to Greece and then the route back to Croatia and blast back to Switzerland.
