Plug chop colours
alanscottj
Scooterdude wrote:Ok those silver speckles would indicate a degree of pre-ignition which would suggest you really need to retard your ignition timing, but as your on a varitronic I really don't know how you would do that.
Try a BR9ES and see how it looks, although I don't think they have a great reputation for longevity, I guess you could try a Champion equivalent to the 9.
I think it would also be useful for me to recheck my timing whilst I'm at it :roll:
Lambretta Series 2 Rat - RB260, SuperTourer, Cyclone 5 gearbox πŸ˜ŽπŸ‘
alanscottj
Ryskie wrote:First three look okay but If it were mine I'd aim for a bit darker. As above try an NGK 9 or a Denso W27ESU
Cheers Ryskie - I'll try a 9 tomorrow :D
GTFOMWSC
Main scooter: GP230 Super Monza CS Tuned
Just rebuilt mine and rejetted etc my plug chops are darker than those running on a b9.It ran absolute crap on an 8 and 7 but really well on a 9, done 600 plus trouble free miles so happy using the 9 starts first kick as well.Mine has been dynoed and plug colour was correct once it was done.I'd suggest before you start messing about adjusting this and that dyno it and let whoever is doing the dyno do the adjusting tbh.
the man don't give a f@@k
Norrie Bodge
alanscottj wrote:Needle raised one clip, darker but not nice to ride, splutters like Image Image
put your clip back into its original position m8 & put a tiny washer under the needle clip ok....
this will give it a half position between what you`ve had it
then seen how its runs, & check your plug
alanscottj
Great idea - something I have done before but I can't find a washer small enough!!! :roll:
Great idea - something I have done before but I can't find a washer small enough!!! :roll:[/quote]
You can buy them here
https://www.dellorto.co.uk/shop/dellort ... le-washer/
alanscottj
Toddy wrote:Great idea - something I have done before but I can't find a washer small enough!!! :roll:
https://www.dellorto.co.uk/shop/dellort ... le-washer/[/quote]
Thanks Toddy but I'm not sure I can bear to pay Β£4.26 for one tiny washer! :lol:
storkfoot
I have loads of small washers. They are a bit too big for the recess in a PHBH slide but 5 minutes with a small file will sort it.
If you PM me your address, I'll pop a few in the post.
Norrie Bodge
Got some brass washers that I use I can send you a couple if PM your address
alanscottj
Norrie Bodge wrote:Got some brass washers that I use I can send you a couple if PM your address
Been away for a week mate and returned to find an envelope with two washers had arrived! Top man indeed - if you happen to be at Llandudno Rally this year there'll be a pint in for you ;)
Many thanks.
Scott
