Page 2 of 2
Re: Engine Case Cleaning
Posted: Wed May 10, 2017 5:56 pm
by mr mugello
I took a 200 Italian case to a well known dealer for a full rebuild. They blast cleaned the casing rough as hell. Don,t know what they used. I was well peed off as I never asked for it to be blast cleaned in the first place, as it was in good original condition. Being rough it gets grubby easily. Would it be possible to make it smoother if using a different media ?
Posted: Wed May 10, 2017 6:13 pm
by holty
yes you want it aqua blasting, i use tony at ajs in hull, it gives it a nice dull sheen, will make it look nice, and easy to keep clean.
holty
Posted: Wed May 10, 2017 10:01 pm
by Scooterdude
mr mugello wrote:I took a 200 Italian case to a well known dealer for a full rebuild. They blast cleaned the casing rough as hell. Don,t know what they used. I was well peed off as I never asked for it to be blast cleaned in the first place, as it was in good original condition. Being rough it gets grubby easily. Would it be possible to make it smoother if using a different media ?
Yes you could use fine beed to "peen" the profile of the ridges back or alternatively, and this is for you as well Martin with the rough Indian cases. Use a bronze wire wheel in a hand grinder, this is how I did my case last January as we are a large mobile blasting contractor and don't have the luxury of a blasting cabinet with glass bead etc, I just blasted the case at as low a pressure as I could with expendable glass grit then buffed it up with said bronze wheel and applied a coat of wax for good measure, the finish still looks great and still doesent hold on to the dirt, I just rinse it off with some Muk off and water every now and again.
Posted: Mon May 15, 2017 10:06 am
by Scoot
fluff34567 wrote:Noooo. Dishwasher dulls the casing !
I did that. I put mine in the dishwasher and it came out a dull Matt!!
Sent from my iPhone using Tapatalk Pro
Posted: Mon May 15, 2017 5:00 pm
by fluff34567
Also be careful if using hot water on a blasted case or carb etc unless it's been laquered. The same happens.
Posted: Mon May 15, 2017 5:06 pm
by Meds
+1 for the oven cleaner and a suede brush
