Page 2 of 2
Re: Dog support
Posted: Sun Apr 02, 2017 5:43 pm
by bristolmod
HxPaul wrote:Unfasten the two bolts and nuts that hold it on to the support leg and remove it.Next place a thick peice of wood under the back of the frame,jack up without unfastening anything and the frame will be raised enough to remove the sidecover
https://www.google.co.uk/search?q=pictu ... pReIKtashM:
but its designed to allow the side cover off easily- something is
amiss. It would appear that the engine as a whole is too close to the support. Either the support is bent in for some reason, or, hopefully not, the engine/ frame is bent out.
Re: Dog support
Posted: Sun Apr 02, 2017 6:57 pm
by hendy
Aye, what he said. I have no bother with this.
Re: Dog support
Posted: Mon Apr 03, 2017 12:40 pm
by gaz_powell
Ive not had any trouble in the past - sounds like your support arm is pushed in ???
Re: Dog support
Posted: Mon Apr 03, 2017 1:01 pm
by bristolmod
engine mount collapsed?
Re: Dog support
Posted: Tue Apr 04, 2017 12:18 am
by fluff34567
As above check engine mounts , do you have offset cones in the frame?
Re: RE: Re: Dog support
Posted: Tue Apr 04, 2017 8:16 am
by dazblakey
fluff34567 wrote:As above check engine mounts , do you have offset cones in the frame?
This is a new one on me can you elaborate please
Re: Dog support
Posted: Tue Apr 04, 2017 9:10 am
by fluff34567
On my frame where I know the leg is out of position I can still get the case off .. should be 20cm.from.frame centre line to the hole in L bracket btw.
If the engine is tilted combined with something else that isn't right then it may be a bit harder to get the case off.
