Re: Kickstart not engaging
Posted: Sat Mar 25, 2017 9:42 am
have you checked that the gears stand proud of the layshaft when fitted, if they dont fit above the end of the shaft you may have a duff gear or layshaft, but end end result is you can never shim the box correctly, i had this on my last build and it was the 4th gear that was too thin, another gear cured it, larger shims are available to 3mm at least, bazza3004 had a good fix of making the slot longer that ive had to do before as well.
