Re: Regulator output
Posted: Tue Mar 21, 2017 10:17 pm
I'm a bit puzzled ? are you saying you'd charge a 12v battery with 7 volts ?
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
No, but many (or maybe all?) Those 12v a.c. regulators with trickle dc output are only good for about 6 or 7 volts dc. This means they are good enough for those 5v usb supplies that people use for charging phones etc. Sat navs are almost certainly 5v too despite having 12v input; as long as the supply is greater than 5v it will be ok.mick1 wrote:I'm a bit puzzled ? are you saying you'd charge a 12v battery with 7 volts ?
dunno about should but think on a 12v when I last measured it was between 1 and 3 ish?mick1 wrote:What should it be ?Donnie wrote:umm not on the trickle it wontmick1 wrote:if it's a 6v regulator I would expect 7v+ and a 12v would be 14+
ummm well yeah, but how long will it take to charge up fully? THAT is the issue.firekdp wrote:If it's a 12v AC reg with a DC take off connection it will charge a 12v battery.
Depends on the size (a/h) of your battery.Donnie wrote:ummm well yeah, but how long will it take to charge up fully? THAT is the issue.firekdp wrote:If it's a 12v AC reg with a DC take off connection it will charge a 12v battery.
All things being equal, about twice as long as a full wave system. However they aren't designed to charge a flat battery, but maintain a fully charged battery, as such, the DC circuits are only low or momentary high loads. Vespa single output stators input about +1A @ 2000rpm and +2A @ 5000rpm into a fully charged battery. However high loads on the AC circuits are going reduce the spare capacity for this.Donnie wrote:ummm well yeah, but how long will it take to charge up fully? THAT is the issue.firekdp wrote:If it's a 12v AC reg with a DC take off connection it will charge a 12v battery.
Correct.Muppet wrote:trickle or full dc when less than 6v goes in it aint chargin if more than 6v goes in its chargin or is that wrong ?
