Page 2 of 3
Re: Cone steering bearing upgrade.
Posted: Sun Feb 26, 2017 3:16 pm
by 10 inch Terror
Donnie wrote:
holty wrote:the bottom bearing has much bigger balls so is stronger, plus you can always add lots of balls and no cage, top however is made with very small balls so isnt as strong, probably aimed at scooters with a good front disc brake, and riders who ride faster,braking hard from high speed will put some load on them little bearings, as do bumpy roads and pot holes, its something i might use in the future
really?
Cheers Donnie.
Posted: Sun Feb 26, 2017 3:17 pm
by 10 inch Terror
fluff34567 wrote:Found it...... Image £58 on ebay
Cheers for that.
Posted: Sun Feb 26, 2017 6:24 pm
by 10 inch Terror
£60 plus £10 postage. I think I'll leave it.
Posted: Sun Feb 26, 2017 6:57 pm
by fluff34567
I think the cost is excessive and would rather have seen a lower taper bearing set up. However if the cones and bearings are in good condition, greased and tightened properly I don't see the need for a taper set on a lambretta.
Posted: Sun Feb 26, 2017 7:15 pm
by Muppet
i like em
Posted: Sun Feb 26, 2017 9:08 pm
by Eibar
Check if now does versions for chrome ring type setups as therse were done initially for non
chrome ring
Posted: Mon Feb 27, 2017 1:42 pm
by tonydevon
try crazy solutions on FB sure he just did these too
Posted: Mon Feb 27, 2017 2:06 pm
by Leo
The top bearing is the one which takes all the braking force and its a good upgrade, the taper bearings themselves are about 25 quid.
I have em but I'm sick of spending money just now! Maybe next year.
Posted: Mon Feb 27, 2017 2:57 pm
by Donnie
Maybe im must not braking hard enough. :shock: :shock: :lol: :lol: :lol:
Posted: Mon Feb 27, 2017 5:14 pm
by holty
Donnie wrote:Maybe im must not braking hard enough. :shock: :shock: :lol: :lol: :lol:
as i suggested earlier a conversion aimed at a slightly higher performance market, my gp has over 50bhp and gets upto speed quickly, hence i do have to brake hard at times, and ive had to adjust the front cone a few times, thats why i will fit one of these when i have it apart, probably a bit overkill on a standard machine thats not ridden hard.
:D
