Page 2 of 3
Re: Compression on TS1?
Posted: Sun Feb 12, 2017 4:46 pm
by alanscottj
Okey dokey, decided to take top end off and have a look. Barrel is spotless but checking rings, put top piston ring into the barrel and the gap is 0.8 - does this mean it is time for new rings?
Posted: Sun Feb 12, 2017 5:58 pm
by garry inglis
this is watt mb recommends
Posted: Sun Feb 12, 2017 6:01 pm
by garry inglis
So 0.8 seems big and might be why the compression is down
Posted: Sun Feb 12, 2017 8:31 pm
by alanscottj
garry inglis wrote:So 0.8 seems big and might be why the compression is down
Yup, measured them both and both are larger than recommended - top ring 0.8 and bottom ring 0.7
Posted: Sun Feb 12, 2017 8:35 pm
by garry inglis
Easy to sort out Alan and you only have to take it easy for 50 miles and should be a lot more responsive
Posted: Sun Feb 12, 2017 10:09 pm
by alanscottj
The piston that I have is a 'B', does this have any bering on the rings I need to get? Or, can I just order normal TS1 225 piston rings
Posted: Sun Feb 12, 2017 11:07 pm
by Padge
just order normal TS1 piston rings and gap accordingly
Posted: Sun Feb 12, 2017 11:26 pm
by alanscottj
Padge wrote:just order normal TS1 piston rings and gap accordingly
Cheers Padge
Posted: Mon Feb 13, 2017 7:00 am
by garry inglis
How many miles on those rings and what 2 stroke are you using just to understand why?
Posted: Mon Feb 13, 2017 11:39 am
by Scooterdude
Also what's your piston to bore clearance am guessing it should be around .003"
