Page 2 of 6
Re: 6000 rpm normal????
Posted: Sat Jan 21, 2017 6:23 pm
by bazza3004
my ts1 reved out to 9500 0n the dyno so it should be higher than 6000 on the stand.
Re: 6000 rpm normal???? NOW WITH GRAPH!
Posted: Sat Jan 21, 2017 10:52 pm
by alanscottj
Found my dyno readout - the red line is the most recent run. I know absolutely nothing about reading dyno graphs. As the engine makes peak power at 6000 revs am I right in thinking that that is the max my engine/pipe combo will make?
Posted: Sat Jan 21, 2017 10:59 pm
by Scooterdude
No because it clearly revs on to 8250. Although it only makes 9.6 at that speed....it must have got there some how...magic maybe?
Posted: Sat Jan 21, 2017 11:09 pm
by drunkmunkey6969
The pipe is not the problem.
I'd suggest you investigate the ignition first.
Posted: Sat Jan 21, 2017 11:22 pm
by alanscottj
drunkmunkey6969 wrote:The pipe is not the problem.
what? Timing changed?
Posted: Sun Jan 22, 2017 9:46 am
by mick1
It's worth getting it strobed to see how far it's retarding as the rev's increase. It may be retarding too far and preventing it revving out.
The more expensive strobes incorporate a rev counter as well.....
6000 rpm normal????
Posted: Sun Jan 22, 2017 9:50 am
by drunkmunkey6969
No, not that the timing has 'changed'....but that there might be a problem with the ignition.
Look at this graph, it's a TS1 with Franspeed Super Tourer, see the red line:
That is what your graph should look like, but when your engine hits its peak at circa 6k rpm.....the power tails of badly, whereas it should go on to peak much higher/later.
So what I'm saying is: It's worth investigating your ignition system, It may be breaking down under load. The pipe is not the problem.
Posted: Sun Jan 22, 2017 10:54 am
by alanscottj
Thanks - I can see the difference now - very clearly! So, how do I go about checking the ignition? Is it as Mick1 says, get it stroked? Or do I check it With a multimeter? Not had much experience with the ignition side of things
Many thanks
Posted: Sun Jan 22, 2017 12:52 pm
by storkfoot
The dyno operator. What conversation did you have with them after that dyno readout, especially about the ignition timing?
I concur with what has been said previously by the way as the dyno graph for my TS1/ Supertourer engine is similar to Dan's.
Posted: Sun Jan 22, 2017 3:28 pm
by alanscottj
I didn't have a chat about the graph to be honest, I just sort of assumed if there was a problem with anything he would of mentioned it. I just took it home and rode it. The blue line was with a JL3 and a different gearbox (GP200) and the green supertourer line was with a AF Close Ratio box - could the close ratio box also account for the drop of power after 6000?
