Page 2 of 2
Re: NK Any Good?
Posted: Fri Jan 20, 2017 9:55 am
by EddieStone
Jazzy wrote:struggle with pictures.
to make a slip joint simply cut straight thru the pipe and weld a band of steel to one part forming a socket for the other part to fit in.
attach eyelets for springs and load the joint with silicon on assembly. allows for rotation and a bit of give when lining up.
there an awful lot of pipe in front of the sharks fin bracket that's only held with one spring from the stub and with a rubber sprung joint on the tailcan its a bit like getting jiggy with a fat bird in a hammock. :D
Oh, as easy as that?! Thanks. I guess spring tension is a bit of guesswork?
Re: NK Any Good?
Posted: Fri Jan 20, 2017 9:58 am
by st0kky
NOTE TO SELF.............must get a hammock !!
Re: NK Any Good?
Posted: Sat Jan 21, 2017 10:20 am
by Timbo
I had one, very very revvy not my cup of tea...
Re: NK Any Good?
Posted: Sat Jan 21, 2017 11:05 am
by Scooterdude
Timbo wrote:I had one, very very revvy not my cup of tea...
I'm guessing you must have had the race version? I was looking at the "mid" version but am still undecided may still go for a Gori once I've managed to run it in.
