Page 2 of 2
Re: Chain case gasket ?
Posted: Sat Dec 24, 2016 8:37 am
by Strummer10
Yes Warts i'll try another breather plug......interesting someone has found a cork chainside gasket in the above post, we were talking about those a while ago and recall they were around in the 80s and we never had leaks with them.
Must confess the grease is indeed easier to deal with when doing a changeover.......
Posted: Tue Dec 27, 2016 11:12 pm
by fluff34567
£4.75 for a cork gasket.. bargain!
Posted: Wed Dec 28, 2016 10:03 am
by hendy
fluff34567 wrote:£4.75 for a cork gasket.. bargain!
Just check that the stud holes are the correct size if you use one. The first ones I got had all the holes punched for m8 studs whereas most should obviously be m6. It was OK for a while but once it started leaking it got worse and worse. Partly my own fault as I noticed when fitting but I was going to breighton ferry the next day so I just crossed my fingers; never seems to work for me, maybe I'm not crossing them quite right?
He did replace them free of charge without question. Just make sure you check.
Posted: Wed Dec 28, 2016 10:10 am
by fluff34567
Ok cheers for that. Will check when it arrives
Posted: Thu Dec 29, 2016 8:33 am
by Strummer10
Ordered 5 cork ones, remembering how much better these seemed in the 1980s lol.....hopefully with flattening out a little the chaincase cover and the cork gasket it will soak and expand to seal any tiny undulations .....
change breather plug as well
Posted: Thu Dec 29, 2016 8:43 am
by fluff34567
I use glass and 2000 grit emery to highlight any high or low spots
Posted: Thu Dec 29, 2016 2:32 pm
by Strummer10
Fluff yes I will do that.....IF I can find a decent length of glass......How about the wife's bedroom mirror lol ?
Posted: Fri Dec 30, 2016 11:42 am
by shocky
I only ever use these green ones from pro porting I grease them and the one on there at mo has been on and off a few times and hasn't leaked
Posted: Fri Dec 30, 2016 11:45 am
by shocky
Sent from my SM-G903F using Tapatalk
