Page 2 of 9
Re: oiltech casing alterations
Posted: Wed Dec 21, 2016 4:57 pm
by shocky
Wow that's alot of porosity in those welds I've welded a fair few cases scooter and m/c I always dipped mine in solvent first then hot washed them if I had blow holes I'd cut them out and redo them
I'll admit I've never put that much weld on one but actually as you put more on providing the first pass has been cleaned up it should do a better job with each pass of weld
Posted: Wed Dec 21, 2016 5:53 pm
by Scooterdude
shocky wrote:Wow that's alot of porosity in those welds I've welded a fair few cases scooter and m/c I always dipped mine in solvent first then hot washed them if I had blow holes I'd cut them out and redo them
Exactly! I'm guessing your only consolation is you only paid £180 and not the £380 I was quoted.
Posted: Wed Dec 21, 2016 8:30 pm
by garry inglis
Well it looks very solid and if I have any problems I'll sort if needed a leek down test will tell when I get it built
Posted: Wed Dec 21, 2016 8:49 pm
by hendy
garry inglis wrote:Well it looks very solid and if I have any problems I'll sort if needed a leek down test will tell when I get it built
Honestly mine was fine. Ignore the nay-saying. Just fill the blow holes with jb weld or something and all will be cool.
Posted: Wed Dec 21, 2016 9:09 pm
by holty
yes i agree, youve done the right thing using jb weld to fill them, i use yambond or similar on gaskets or where there isnt a gasket without any problems, and like you say a leak down test will be well worth doing, keep the pics coming, some good work there, ive got a few welding flaws on my 290 rotax conversion and thats going to get the jb weld treatment as well,
holty
Posted: Thu Dec 22, 2016 4:53 pm
by Ken Tucky
Well if its of any help, I've used JB Weld on my Sprinter Crankcase, where, trying to weld anymore in the crank area would just cause more porosity, and its been fine. Its a crankcase that's had a fair bit of welding btw.............
Richard
Posted: Thu Dec 22, 2016 5:03 pm
by garry inglis
i have total confidence in the welding oiltech do 8 casings every 6 to 8 weeks so there must be a lot out there that are fine the way he does them i am more botherd about what top end to pick gt200 /rb225 /avanti 225 or ts1
Posted: Thu Jan 05, 2017 2:45 pm
by garry inglis
Brake shoes on and li ramp fit ready for kit
Posted: Thu Jan 05, 2017 4:12 pm
by bazza3004
Had a case coverted about a year ago. If you want the welding cleaned up / reshaped they will do this for you (or would when mine was done) at extra cost. Personally i didnt bother as it aint visible when engines in anyway. There were a couple of tiny bubble holes on gasket face but nothing that was going to cause a problem and a leak test confirmed this. Good luck with your build.
Posted: Sat Jan 07, 2017 2:38 pm
by garry inglis
All the bits now went to rayspeed yesterday ts1 kit 30mm Vhsh mid flywheel also bgm stater and a gt 60/110 crank ads5 or franspeed super tourer to choose from
