Page 2 of 2
Re: Quattrini which exhaust
Posted: Sat Dec 03, 2016 9:50 pm
by Knowledge
cartmel808 wrote:SIP sell hhpv4... 4 pre-set ignition curves - set @ 0 for quattrini
That is quite an assumption. I would have opted for a dyno run on each setting (it will lake 5mins) and then over lay the four graphs and opt for the one that looks the best, and the one that looks second best. Then road test to these two settings. The answer might not be 0.
Posted: Sun Dec 04, 2016 10:00 am
by ducksta
Cheers will keep my eyes open
Posted: Sun Dec 04, 2016 1:03 pm
by cartmel808
Knowledge wrote:cartmel808 wrote:SIP sell hhpv4... 4 pre-set ignition curves - set @ 0 for quattrini
Not an assumption - although having re-read my post I was very vague & what I should have said is 'I found he '0' setting to be best suited to my quattrini engine'...
I did have mine set-up on a dyno with the HHPv4 being ran through all 4 settings in exactly the way you've described (and re-dyno'd with each change of exhaust)... I also road tested the engine extensively, switching between the two best settings & settling on '0' as the optimum curve for my engine.
Posted: Sun Dec 04, 2016 4:10 pm
by Knowledge
Thanks for the clarification Cartmel808.
Posted: Sun Dec 04, 2016 4:26 pm
by cartmel808
Posted: Sat Dec 24, 2016 9:20 am
by Mark G
Hi are you still happy with your pipe design pipe. Which one are you using and how much was it as there web site has no prices. I did see there stand at German rally and they looked well made. i was going to get the quattrini mpx3 but now im not sure lol
Posted: Sat Dec 24, 2016 3:52 pm
by cartmel808
Mark G wrote:Hi are you still happy with your pipe design pipe. Which one are you using and how much was it as there web site has no prices. I did see there stand at German rally and they looked well made. i was going to get the quattrini mpx3 but now im not sure lol
Yes very happy with mine... I went for the Bullet 177 (on Marco's recommendation) and at the time I think it cost €390 euro plus p+p - that was for the stainless steel version.
