Quattrini which exhaust
Knowledge
cartmel808 wrote:SIP sell hhpv4... 4 pre-set ignition curves - set @ 0 for quattrini
That is quite an assumption. I would have opted for a dyno run on each setting (it will lake 5mins) and then over lay the four graphs and opt for the one that looks the best, and the one that looks second best. Then road test to these two settings. The answer might not be 0.
Martin
ducksta
Cheers will keep my eyes open
cartmel808
Not an assumption - although having re-read my post I was very vague & what I should have said is 'I found he '0' setting to be best suited to my quattrini engine'...
I did have mine set-up on a dyno with the HHPv4 being ran through all 4 settings in exactly the way you've described (and re-dyno'd with each change of exhaust)... I also road tested the engine extensively, switching between the two best settings & settling on '0' as the optimum curve for my engine.
Knowledge
Thanks for the clarification Cartmel808. :D
Martin
cartmel808
Mark G
Main scooter: Ts1 px177 gts300
Hi are you still happy with your pipe design pipe. Which one are you using and how much was it as there web site has no prices. I did see there stand at German rally and they looked well made. i was going to get the quattrini mpx3 but now im not sure lol
cartmel808
Mark G wrote:Hi are you still happy with your pipe design pipe. Which one are you using and how much was it as there web site has no prices. I did see there stand at German rally and they looked well made. i was going to get the quattrini mpx3 but now im not sure lol
Yes very happy with mine... I went for the Bullet 177 (on Marco's recommendation) and at the time I think it cost €390 euro plus p+p - that was for the stainless steel version.
