Page 2 of 2
Re: Fast Idle Speed
Posted: Wed Nov 16, 2016 2:56 pm
by EddieStone
First thing I would do is make sure your throttle cable is seated properly at both ends.
Re: Fast Idle Speed
Posted: Thu Nov 17, 2016 3:41 pm
by Maladjusted
Carb jets removed and all cleaned with compressed air. Seems to be working fine now. Must be the Sainsbury's petrol :shock:
Re: Fast Idle Speed
Posted: Thu Nov 17, 2016 6:21 pm
by ducksta
You could of blocked the tap with shite if you jacked it up take tank cap of and put air through the petrol pipe to eliminate this
Re: Fast Idle Speed
Posted: Thu Nov 17, 2016 6:24 pm
by ducksta
How did you jack it up?
Re: Fast Idle Speed
Posted: Thu Nov 17, 2016 8:18 pm
by Maladjusted
With a car jack from the very back of the scooter :?
Re: Fast Idle Speed
Posted: Fri Nov 18, 2016 2:49 pm
by GFlint
Might seem daft but is the throttle cable outer seated correctly? Sometimes they rest on carb housing and not pushed in right which makes it race.
Gaza
