Page 2 of 2
Re: Wheel nut query?
Posted: Sat Nov 12, 2016 12:16 am
by corrado
Timbo wrote:What's best for attaching the side casing?
I'm using allen fixing studs that are easy to fit with an allen key, no double nutting needed, then flat washer, wavy washer and a standard nut. Never use nylocks on chaincasing as they're likely to bring the stud out when undoing them.
Posted: Sat Nov 12, 2016 10:15 am
by Tractorman
DigDug wrote:Timbo wrote:What's best for attaching the side casing?
Standard nuts and a wavy washer.....
Fully agree with this, using capscrews (allen headed bolts) encourages thread wear with use. Try and get the deeper original type nuts.
Posted: Sat Nov 12, 2016 11:58 am
by HxPaul
Studs,wavy washers and stainless dome nuts,have used them for years with no leaks and they never come loose.
Posted: Tue Nov 15, 2016 12:08 am
by corrado
Tractorman wrote:DigDug wrote:Timbo wrote:What's best for attaching the side casing?
I'm not using allen bolts, I'm using studs that fit using an allen key.
Posted: Tue Nov 15, 2016 10:34 pm
by mr mugello
I hope your Nylocs are better than the ones I have just got. Just using wavy flat washers , the studs just touch under the Nyloc ends. Nyloc seems too high up, not doing their job. Or either my studs are shorter than normal length.
Posted: Wed Nov 16, 2016 1:03 pm
by Doom Patrol
Are these still domed nuts you're talking about? At the risk of labouring the point they are a lottery. Use standard nylocs and be safe.
Posted: Wed Nov 16, 2016 4:41 pm
by HxPaul
Doom Patrol wrote:Are these still domed nuts you're talking about? At the risk of labouring the point they are a lottery. Use standard nylocs and be safe.
If your talking about wheel nuts,using standard nylocs can be a bit of a lottery too.Some nyloc nuts are too long and the thread of the wheel rim/hub wont reach the nyloc part.If your using standard nyloc nuts,always get the shorter ones.
Posted: Wed Nov 16, 2016 4:50 pm
by Doom Patrol
Ah, then we've all learned something. I hadn't realised that there were two lengths of standard. Seems a bit bizarre to me.
Posted: Wed Nov 16, 2016 8:04 pm
by mr mugello
Drop of liquid threadlock is worth doing too
