Page 2 of 2
Re: Best LED rear brake light?
Posted: Sun Sep 18, 2016 10:38 pm
by holty
ive got one on an ac and one with dc they work fine on both, ac is not quite as bright as dc only on a slow tickover, and it doesnt dim the headlight at all, and thats 55 watt
Posted: Sun Sep 18, 2016 10:52 pm
by YAMLAM
immylam wrote:Had a couple of the BGM ones and they are pretty good .....for the 6 months they work....
Had one since they came out still bright.
Posted: Sun Sep 18, 2016 11:10 pm
by Grumpy225
Just look up 1157 LED lamp
Lots of off the shelf options and can be picked up at your local auto parts store.
Posted: Sun Sep 18, 2016 11:12 pm
by HxPaul
Scooterdude wrote:HxPaul wrote:Just for a bit of balance,I have used an LED bulb in the rear of my series 3 for over a year and it is not dim but quite bright,the best part about it is that when I use the back brake the lights dont almost go off,but stay bright.
Is yours the full DC system with battery? Mine is AC no battery and I'm using a 55watt halagen front bulb which is very bright, but as you say when you brake even with the led back bulb the front light almost dies.
I read somewhere those led back light units must be used only with DC current ?
Mine is an A/C 12v system with a white Zenon headlight.Just to confirm,when I brake with the LED rear,the headlight doesn't dim but stays bright.
Posted: Mon Sep 19, 2016 9:07 am
by HxPaul
HxPaul wrote:Scooterdude wrote:HxPaul wrote:Just for a bit of balance,I have used an LED bulb in the rear of my series 3 for over a year and it is not dim but quite bright,the best part about it is that when I use the back brake the lights dont almost go off,but stay bright.
Mine is an A/C 12v system with a white Zenon headlight.Just to confirm,the rear light IS a replacement bulb and I've just removed my normal bulb and replaced it with the LED one,when I brake with the LED rear,the headlight doesn't dim but stays bright.
Posted: Mon Sep 19, 2016 10:37 am
by immylam
2 I am using just now are both off e-bay.
One has a white plastic backboard and a large number of rear & brake lights in strips fixed on with tie wraps. Very good , loads of light and brake , was made by a scooterist , - £20 I think.
Other is a £5 universal led rear light , took the light unit out of the casing/lens and easily fettled to line up with lammy rear light screws, also very good.
The BGM ones I had both packed in on the braking lights part of the light although the rear light still worked.
Posted: Tue Sep 20, 2016 9:08 pm
by alanscottj
immylam wrote:2 I am using just now are both off e-bay.
I've just ordered the one like you got off eBay - fella on here makes them (Holty) hope to get it fitted for the weekend as the nights are drawing in
Posted: Sun Sep 25, 2016 2:39 pm
by essexgp
I had an Atomic one on my Ac GP which worked great for about a month then went really dim so went back to a good old reliable bulb
