Page 2 of 2
Re: Spanish series 2
Posted: Fri Sep 09, 2016 7:11 pm
by hendy
storkfoot wrote:I had those bgm ones on mine. Use the mudguard to trap the nut against the damper mount and screw in from the other side ;-)
I think I'll half pinch that idea and weld the nut to the outside of the damper mount. Or weld the hole up, add 3mm plate then drill and tap.
Posted: Fri Sep 09, 2016 9:09 pm
by storkfoot
The nut won't actually touch the mudguard. I stuck a bit of foam between the nut and the mudguard and that held the nut in place. It was easy in the end.
