Page 2 of 2
Re: BGM clubman
Posted: Tue Aug 30, 2016 2:35 pm
by storkfoot
My early Mb/bgm Clubman is 17mm internal diameter. As far as I know, they have remained the same.
Re: BGM clubman
Posted: Tue Aug 30, 2016 3:03 pm
by whonatic
Thanks everyone - I also forgot to mention running an avanti head too just to try and keep cool, but that's not made much improvement - clearances are pretty big, 4 thou - tuner checked before he built it up as its running a Yam DT250 piston and he says you can run the bigger clearances with those Pistons.
The ONLY thing left is the pipe ??
Re: BGM clubman
Posted: Tue Aug 30, 2016 3:29 pm
by camel
Those carb settings seem rich enough to keep it cool..i take it the avanti head was profiled for a yam piston?..
Re: BGM clubman
Posted: Tue Aug 30, 2016 4:10 pm
by jonzo172
Darrell Taylor has previously commented regards the restrictive tail pipe size on larger cc engines... 4 comment down the page:
http://scooterotica.org/forum/viewtopic ... an#p269927
Re: BGM clubman
Posted: Tue Aug 30, 2016 4:43 pm
by whonatic
camel wrote:Those carb settings seem rich enough to keep it cool..i take it the avanti head was profiled for a yam piston?..
Yes had it profiled to suit. But to be honest it was doing the same on a previous AF head that was fitted. If I could weld, and build my own clubman I would, but I don't know anyone that does something so involved !!
Re: BGM clubman
Posted: Tue Aug 30, 2016 4:54 pm
by camel
Are you experiencing any "pinking"under load?
Re: BGM clubman
Posted: Tue Aug 30, 2016 5:14 pm
by whonatic
camel wrote:Are you experiencing any "pinking"under load?
None - which is surprising
Re: BGM clubman
Posted: Tue Aug 30, 2016 5:37 pm
by camel
Does sound an odd one...good bore clearance..rich jetting..no pinking..so i can see your train of thought for the pipe....
One more thing..after seizing do you remove the barrel?alluminium deposits could replicate a tight bore in places.
Next for me id swap the pipe(altho im still not convinced) for anything you have laying about and try that to prove it out.
Re: BGM clubman
Posted: Tue Aug 30, 2016 5:54 pm
by whonatic
camel wrote:Does sound an odd one...good bore clearance..rich jetting..no pinking..so i can see your train of thought for the pipe....
Your not wrong - I'm going bald scratching my head as it's definitely a new one on me. Ideally, I'd like to get my hands on Ron Moss clubman , I've had a few and still run one on another almost identical set up , runs brilliantly ( just the insides rattling it's tits off )
Or I'm waiting for the new improved GP50 gori pipe to come into stock at Rimini.
I wasnt convinced by people telling me it's the pipe either but it's literally the only thing left
