Re: backfiring.
Posted: Wed Aug 24, 2016 8:47 pm
Could it be air leak causing pre ignition. Had similar problem couple of years ago . Changed everything electrical / crank- top end & backfiring continued. Only thing NOT changed was the engine case which is early jet200 used for the first time.
First engine I ever gave up on( it's still on a shelf in the garage)
My thinking at the time was a hairline crack in the crankcase area, or not sealing properly on the inlet side......
