Page 2 of 2
Re: Micron Pipe
Posted: Tue Jan 13, 2009 8:30 pm
by camel
is it for a lambretta?....sorry couldnt resist
is it an msc micron?or some sort of far east copy?
Re: Micron Pipe
Posted: Wed Jan 14, 2009 12:40 am
by paulmgreen
but other than that its ok lol?
Re: Micron Pipe
Posted: Wed Jan 14, 2009 12:41 am
by cranky
I'm TOLD it was for a Lambretta....however I am not so sure.....
I am lead to believe that the item was originally supplied by MSC.
Re: Micron Pipe
Posted: Wed Jan 14, 2009 12:59 am
by camel
find one of powoltti,s posts and click on his web page and search lambretta exhausts,theres a pic altho its a bad one of the msc micron pipe,see if it looks like the one you have,websters stuff was allways spot ot on generally.
Re: Micron Pipe
Posted: Wed Jan 14, 2009 6:50 pm
by shocky
cant help with the reason the pipe wont fit to the manifold but the hole lineing up prob coulbe that the pipe was made for a shorter or longer barrel IE a jap piston conversion his will move the exhaust studs closer or further away from the 8mm side case studs have you tried fitting the exhaust to the engine without the manifold fitted
o and fill yur profile in so we can see were you live someone local might be able to help ;)
