5 speed box.
10 inch Terror
Xbox live gamer tag: No.
The ones I've seen @ £800-£850 obviously are not the supreme version then. Even so if you add £100 for an MB lay shaft it's still £200 more. That's not exactly pocket change.
Grumpy225
10 inch Terror wrote:The ones I've seen @ £800-£850 obviously are not the supreme version then. Even so if you add £100 for an MB lay shaft it's still £200 more. That's not exactly pocket change.
even more if you're paying someone else to do the work
