Page 2 of 3
Re: Suggestions please.
Posted: Tue Jul 12, 2016 8:13 pm
by 10 inch Terror
HxPaul wrote:If you have a copy of the second edition of sticky's manual,turn to page 147,under "carb removal" theres a photo which shows the orientation of the fuel tap and fuel tap rod.As for the rubbers,they shouldn't be on the bend.
They are not on the bend, it's probably where they are squashed by the straps. I may of over tightened them slightly.
Posted: Tue Jul 12, 2016 8:16 pm
by 10 inch Terror
Doom Patrol wrote:What about turning the tap in some more so that the rod passes behind the carb? Looks like the rod would be long enough.
I've found 3 of the little unions that go between the tap and rod. I'll shorten the rod slightly and hopefully the unions should give me enough flexibility to get a smooth enough action?
Posted: Tue Jul 12, 2016 8:36 pm
by HxPaul
I think the reason the rubbers look like there on the bend is because the tank needs turning (see EDIT in my last post)
http://lambrettarestorations.blogspot.c ... -tank.html
Posted: Tue Jul 12, 2016 8:50 pm
by hendy
I had the same problem when I switched from 25phbl to 30phbh.
Fixed it with this.....
http://www.lambrettaspares.com/spares/s ... b0838.html
Posted: Tue Jul 12, 2016 10:26 pm
by Grumpy225
You're missing the little brass knuckle that comes on the fuel tap, tap looks a little on the low side, tank straps are over tightened (squashed out rubbers) and you need to rotate the tank clockwise a little.
There is enough play in the tank/tap set up to clear almost every carb set up (especially the common ones).
Posted: Tue Jul 12, 2016 10:50 pm
by HxPaul
Grumpy225 wrote:You're missing the little brass knuckle that comes on the fuel tap, tap looks a little on the low side, tank straps are over tightened (squashed out rubbers) and you need to rotate the tank clockwise a little.
It depends which side of the scooter you turn the tank,from the carb side its anti-clockwise.
Posted: Tue Jul 12, 2016 10:52 pm
by Chris in Margate
You need GP rubbers under the tank to lift it higher so you can rotate it anti clockwise.
Posted: Wed Jul 13, 2016 6:10 am
by 10 inch Terror
Cheers guys, I'll adjust the tank to get it to sit right, however, I don't think that will help with the rod clearance issues.
Posted: Wed Jul 13, 2016 12:18 pm
by HxPaul
See photo of carb side of engine.This is how it should sit.
http://www.ebay.co.uk/itm/Lambretta-Eib ... 3641.l6368
Posted: Wed Jul 13, 2016 3:36 pm
by 10 inch Terror
Most helpful that. Thank you very much..
