Page 2 of 2
Re: could have been worse.....
Posted: Mon May 16, 2016 6:21 am
by 10 inch Terror
HxPaul wrote:I have a Grand Turismo chain guide,the bottom support hole I use a stud,penny washer and a nylock nut.The top hole I use the supplied counter sunk screw loctited into position.I have to use the counter sunk screw for the top hole because I use the guide to pull the chain down and the chain would foul on a stud and nut.
Good option.
Posted: Mon May 16, 2016 7:02 am
by Donnie
Very good option, not thought on that as I use it to pull down too.
Posted: Tue May 17, 2016 10:06 am
by corrado
I supply them with a tab washer for the 2 bolts on the tensioner block too and also use a stud and large washer on the bottom crankcase hole on my own.
Posted: Tue May 17, 2016 10:48 am
by eden
I Lock tight and punch the countersunk screws. The one in the picture looks like it doesn't have the double tab washer under the two bolts that fix the nylon slider to the plate. Defo bad fitment rather than bad product.
