Re: Bgm dampers on turning mudguard
Posted: Sat Jun 24, 2017 6:19 pm
I don't just done a set and with anti dive it was even more awkward
I converted the links (as I have a jig and done 100,s of sets)
But with the lug in the normal position the screw in pin stuck out to far and the bgm damper wouldn't run square up the fork leg when viewed from the front
So I had to move the weld on bottom lug to a different position a few times and then move the top one around a bit as well
There's alot more to it than the above and we still have to pack the mudguard out either side on the mounting bracket probably by 2 mm
Pm me if you need any advice
Sent from my SM-G903F using Tapatalk
