Page 2 of 2
Re: small block kit advice
Posted: Mon Feb 22, 2016 10:06 am
by nellyboyo
I've got an imola and a long stroke mugello with a reed valve so I can only speak for these 2.
The imola is mental and mugello more bottom endy and smoother. I could go on .......
Posted: Fri Feb 26, 2016 9:19 am
by Timbo
I would go for the RT, superbly engineered with plenty of potential for increased performance if you decide you want more from yor scoot..
Posted: Fri Feb 26, 2016 4:57 pm
by Burnside
002pg wrote:Thanks for the replies.
I am just after a standardish kit for a bit of a runaround, as I am in jersey its just for short trips 1 up, got standard gp200 gearing with 22mm carb and a mbbgm clubman. Don't really want to go reed valve or big carb as I also have an rb22, just want something to putt around on.
Casa 185 sounds ideal for this...personally I like the GT kits but maybe overkill for what you want?
Posted: Sat Feb 27, 2016 1:45 am
by Padge
Iv'e had a few good results using a GP 150 barrel bored to 62/64mm (175/186) play with inlet and exhaust timings but don't go too wild (140-145 inlet and 165-168 exhaust) flow/match transfer feeds 22mm carb, drilled airbox, final drive circa 5.2-5.4 and a clubman.
It will never set the tarmac alight but should havea lot more grunt throughout the rev range and doesn't hit a brick wall at 6,000 rpm
Posted: Wed Mar 02, 2016 8:39 pm
by 002pg
Thanks for the replies, I've decided to go for the rt kit and see what its like with the 22mm carb and maybe upgrade to a 25mm carb in the future.
Posted: Wed Mar 02, 2016 8:47 pm
by garry inglis
ive just been on mb site and out of stock on rt195 kits I would ring them up for when the next batch is in
Posted: Wed Mar 02, 2016 9:39 pm
by Doom Patrol
Try Scooter Centre in Cologne.
Posted: Thu Mar 03, 2016 10:31 pm
by Padge
002pg wrote:Thanks for the replies, I've decided to go for the rt kit and see what its like with the 22mm carb and maybe upgrade to a 25mm carb in the future.
if your changing to a bigger carb but want to retain the original look I prefer a 24mm PWK on correct manifold, so original bellows, filter and drilled airbox can be used, cheaper,smaller and more compact, they run a lot smoother/cleaner low down, snappier throttle response and a doddle to jet in
