RAPIDO RACE 225 GEARING
pasner
so 15/46 or 16/46 would be good. what about the chain, should I maintain the standard one or change it? thankx.
Diablo
changing the front sprocket from 15 to 16 is a big jump.
Although I've not built a Rapido Race 225 I know they are peakey. I would stick with Fishis ratio of 5.2 which for you means Li150 and 15/46 sprockets
fishi
again, tell us your timings and then we can tell youu something about the gearing.
The Rapido 225 Race needs a ratio of about 5.20, the JL3 you will use pulls at low revs.
fishi
pasner
All right then. I will post again when I get the barrell. Thank you all.
Fishi, have dynoed your egine? Could you tell us any information about the top speed and so? thanks
fishi
hier my dyno run:
was made with the AF-NK exhaust, now I use the JL4-Race, has gained a little more power, I thing so.
