Series 2 headset Clamp Thread Size
nellyboyo
Yes, I wish I`d bought a longer hose really and put it through the side of the headset and under the connector block , but I`m not buying another hose .
I sell the Venhill kits and had some sets made up 120mm longer for S2. If you've not used the Hel one you could always sell it on so not a total loss. I find the Venhill ones much easier to work with as the ends swivel until you finally tighten them up, the Hel one I has was fixed so wanted to go where it wanted to go and not where I wanted it to go.
You don't want to be lying on your deathbed in years to come with £30 in your pocket wishing you'd have bought the correct length brake hose all those years ago. :lol:
nellyboyo
I wish I`d known that s2 ones were longer now....
I`ve made something quite tidy up in work now that should make the Allen bolt head well away from the hose so there shouldn't be a problem .
Will try it when I get home ... :roll:
