what problems are most common building a lambretta gp
HxPaul
Try to find a scooter shop nearby that sells the parts you need,that way you can return them if they dont fit.This saves you accumulating rubbish,not to mention saving money.
stroutsy
Main scooter: lambretta gp
what parts most commonly don't fit?
LI150
Main scooter: Series 2 LI150
I am just finishing doing this and I would not choose to do it again.
As said its best to buy from good dealers and dry fit everything. The reason I would not do it again is the cost of all the small things. For example the internals of the headset, can't remember exact cost but it's expensive. Forks also, links springs rods etc.
I will do another resto at some point as I'm now onto number 4 and enjoy doing it but next one for me will be a complete scooter with all the body work.
bristolmod
stroutsy wrote:what parts most commonly don't fit?
most of them.
Scootering since 1968.
Handle bars, top and headlight rim, difficult to get three to match up nicely, right on the top of the bike, difficult to hide if they are not nice.
Dry build is essential, as is ensuring the frame is straight to put all the bodywork onto, you don't want to find something out of line after it's all been painted, make sure the stand strut is strengthened and straight.
Use the manual and build from the rear floor boards back up to the leg shields to get the best gaps, you shouldn't have any trouble with tank air box, tool box etc, engine should be no problems at all.
chippy
LI150 wrote:I am just finishing doing this and I would not choose to do it again.
Couldn't agree more. This is first time I have not bought a complete bike to do and its a nightmare. Finding decent bodywork is near impossible.
Meds
Main scooter: Li125s
Here is some advice I was given and some I have worked out for myself.
Headset top/bottom and rim,try and buy a complete set as said previously
The side panel fit is completely unadjustable so that's your starting point, everything else has some adjustment.
Buy a decent set of rubbers for the bodywork, they will help everything else fit
Find a dealer or dealers you can trust and use them.
You will have to fettle almost everything
scooterslag
You're get days when you'll feel taking a hammer to it, but persevere - it will be worth it. Yep good dealers, ask lots of questions on forums, buy Sticky's book and you'd be fine. Good luck and enjoy. Paul ;)
The mack daddy on the left!
alanscottj
Buy a Dremel, a proper one not a cheap Chinese one. You'll need one.
As has already been suggested, don't buy cheap (as they say, buy cheap, buy twice) buy the best you can afford.
Ask lots of questions on here :D
stroutsy
cheers for the heads up guys, seen a lot of dremels being used in build and it seems like a very useful tool so i will definitely be investing in one
