info on early indian lambrettas
roadrunnerian
thanks for your replies the numbers on the frame are not clear the engine number looks like a blind man has stamped it has plastic rear mud guard but steel tool box the horncast is stamped with the Italian stamp and the colour is a dark mustard not orche . I had a bright yellow 12volt 200 from indian from horners in 79 least said about that scooter the better :D
bazza3004
heyup ian , my mate had a indian gp 200 from AF in 79 that was black. my 79 frame stamp doesn't look too bad to be honest. il show you when you call round fot brew. have a good xmas mate.
"I had a bright yellow 12volt 200 from indian from horners in 79 least said about that scooter the better :D", is this a case of 'rose tinted spectacles' as it probably wasn't even that good! :lol:
shocky wrote:
bristolmod wrote:Jo Guest was Mike Karslakes daughter I believe.
Chris
yes chris thats correct and the picswere taken on Clapham common
Don't you mean Jo Wood?
Jo Guest was another type of model altogether - not that I saw any of her work you understand... ;)
Yes your right
Sent from my C5303 using Tapatalk
One was wood, the other gave wood.
roadrunnerian
thanks for the replies :D
sydduckett
rosscla wrote:
Chris
I was thinking that, lovley pair mind... :D
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 1 guest
