Re: Issue with Rapido
Posted: Wed Dec 16, 2015 3:01 pm
Cheers everyone
and/or a stator.Chris in Margate wrote:Try another CDI first
Cheers for thateden wrote:and/or a stator.Chris in Margate wrote:Try another CDI first
I do leak down tests with the piston at BDC so that the ports are all open.
Mine isn't. FfsYanker wrote:The inlet is closed!eden wrote:
I do leak down tests with the piston at BDC so that the ports are all open.FFS?
Go on then: How do you thoroughly 'leak down test' that? Yes with the inlet open and the manifold plugged FFShendy wrote: Mine isn't. Ffs
OP says it's got a reed valve and DT250 piston. If that has an inlet window then bdc would be fine I thinkYanker wrote:Go on then: How do you thoroughly 'leak down test' that? Yes with the inlet open and the manifold plugged FFShendy wrote: Mine isn't. Ffs
LOL, jesus you must run a tight piston to bore clearance.Yanker wrote:The inlet is closed!eden wrote:
